Try if you find the Tuner Server among the Plugins that can be added to the image.Server Tuner functon is not found ont the new Open Black Hole image v0.1.
I will check that directlyTry if you find the Tuner Server among the Plugins that can be added to the image.
I have the following but dont know how to install it it has been used on openvix in gemini images
so should be able to work on open-blackhole.
how would one install this to what folder location and how to activate anyone point me in right direction please
Many Thanx in Advance
H0nch0
this is great working perfectly
Here is the installer
Ftp the tgz file to your STB to /tmp/ directory
Using your RCU ( remote control unity )
Press <GREEN> <YELLOW>
Scroll down until you found ---> Manual Install BH Packages
Press <Ok>
Restart Enigma
To configure upon restarted
Use your RCU
Press <GREEN> and choose <BH_Tuner-Server> and <OK>
Configure
Best regards
How mount?
I have mount pen drive 32 GB
On media/usb
