Tuner server
porcusor1
Hello,
I have this question:
Vu+duo2 used as server tuner.
With vu + zero can see on vu + duo2 programs, but only with mediaplayer.
With EMC does not work!
Is there another plugin / player that can be used?
Thanks!
Hello,
Thanks!
You can use the feature "Remote channel stream converter" to link streams directly to Channel list
