tuner settings for PIP
stan14
I have a problem setting up tuner A and B in order to work PIP. I activate it via blue button, but I can not change a pip image. When do so, it says, there is no tuner. I have 2 separate satellite dishes with 2 separate cables connected to tuner A and B. Any ideas? Iam using BH 2.0.1
Please post here the configurations of both Tuner A and Tuner B (if it's easier for you also the screenshots are ok)
tuner a
configuration mode- simple
mode-single
satellite- hotbird
diseq-no
tuner B
tuner a
mode-single
satellite- astra
diseq-no
Probably you should download/update the channel settings for hotbird and astra.
If you have manually tuned the channels for astra or hotbird and subsequently modified/switched your setup, remember to tune again the channels selecting the corresponding tuner.
When opening your channel list, you should see in bright white the channels that you can select for PIP, and grayed out the ones that cant't be selected because the requested tuner is already busy.
