Tuner setup
Basil
I have a motorized dish and a fixed dish with 2 lnb (19.2e & 28.2e) i also have a 4way diseq switch.
How do i configure the tuners.(vu+ ultimo)
A noob's guide will be appreciated.
Thanks.
Sent from my GT-I9100 using Tapatalk 2
I think the most effective is to use one tuner for motorized dish
and another for diseq/ fixed dish,
so you could record from different satellites
But I personally have only motor.
Thanks for your reply.
Which goes to tuner A/B?
How do i configure the fixed dish?
Configure mode...simple?
Mode......Diseq A/B or A/B/C/D (i have a 4way diseq switch but only 2 sats are installed at the moment)
Set voltage and 22KHZ ...Yes or No?
Send diseq only on satellite...Yes or No?
Am confused...
Pls help a newbie.
I have no disqc so I do not know the exact answer
But I think that it is not difficult to test and choose the best configuration.
Maybe someone knows on the forum.
Probably should go motorized dish to tuner A
Simple
Mode Positioner
tuner B
Simple
Mode DiSEqC A B C D (C and D nothing connected)
Do you have 2 or 3 dvb-s2 tuners in your ultimo ?
If only 2, then Tuner A simple, diseqc A/B/C/D, port A 19.2 or 28.2 and port B 28.2 or 19.2 (depending which lnb is on which port of your swtich).
Tuner B, simple, positioner.
If 3 tuners, Tuner A, simple, 19.2, diseqc no (and remove your 4 way switch), Tuner B, simple 28.2, diseqc no, Tuner C, simple, positioner.
I have 2 dvb-S2 tuners,i have the positioner on Tuner A,i will reverse it and observe the difference...
Thanks for your input.
