tunner problem
kami2k
I am not getting weak tps get tunned on my solo2, where as in dm800 they are working fine, why is this problem and how to fix it anybody help plz?
Maybe your receiver is not good or Perhaps to try and another LNB.
My tests comparisons a few months ago showed that solo2
has at least as good tuner
compared to the DMM receivers 800HD/500HD/8000HD
VU+ Duo/solo/duo2
Try adding them with a Bouquet or channel list. They might be slightly too weak to "find" but you should be able to watch them if they're already in your list.
