mirza_bole
I have vu+ solo, with external USB HDD ext3 and 32G USB flash that I used to extend flash memory.
I try to install tuxbox to connect it with my PC using XBMC, but I fail every time. On the screen it shows like all is done ok, but it does not ask me to reboot. I did hard reset manually but no tuxbox plugin installed, can not find it. Did it several times, but with no good
Can anyone pls tell me where I am making mistake? Or if there is any other way to stream from Vu to XBMC on my PC?
thx a lot
thx a lot
