Tv channels backup
Maheen.imtiaz
Hi all my great experts here,how can i save & make back up of my tv channels in the vu+duo2 becoz after installing a new image i have to retune all my 16 satellites channels so plz help me to slove my problem.
dreamboxedit is quite simple to use.
First you need to setup a new folder, on your PC's desktop, called Settings, this is the default location of the Dreamboxedit tools, but can be changed, if you want to.
Right mouse click, on your desktop, select the new Folder option, and name it Settings.
Now you need your receivers IP address, in order to connect dreamboxedit to your receiver.
Go into your VU+ menu, Setup, System, Network, select the connection, you're using WLAN, for wireless, lan for cable, then click on Adapter Settings and not down the IP Address.
Start up dreamboxedit, Click on Tools, and options, in the IP Address box enter your receivers IP Address, and click Save.
Now click on File, and Fast FTP Download, and you should now have a full backup of your receivers channels, and bouquets, which you can edit, then upload back to your receiver, at any time, using the fast FTP Upload option.
Bundle of thanks dear i will try
