TV Remote Control and OpenBH
medamine60
Hello all,
I'm using my Sony remote to control my Vu+ reciever !
But when I start Kodi the RC is not working at all and with Media Player I could not use key 1,4,7 and 3,6,9 for rewind and Fast Forward.
Any chance to have it work?
Many thanks
A
Hello all,
Many thanks
A
No ... Use instead the original vuplus remote control.
Hi Nunigaia,
Ok I see, Yes it's works with the Vu's one, but Sony RC is much better and have an integrated MIC.
BTW I said before that the manufacturar should be more innovative to avoid the same story that happen to Dream Multmedia ;-)
http://www.vuplus-community.net/board/threads/voice-assistant-on-vu-recievers.39817/
Thanks for feedback
Regards
A
I don´t care what about DM has promised, and then, this was the way i turned over to Vuplus a few years ago.
In any case, you are not talking about a BT IR remote control but about a third party RCU ( Sony ).
There are things more important to fix, then to make a third party RCU work, on a Vuplus STB.
