Twin tuner and recording
magmo
Hi
I have the VU+ Solo 2, when I record one channel that is encrypted I can only watch channels that is not encrypted while recording. Is this by design or have I setup it wrong?
I have 2 identical coax connected to the receiver that both is connected to a diseqc and Thor, Astra, Hotbird, Astra 2.
OBH 4.3
Because that (encrypted) factor is not related to the problem... you may be recording an encrypted channel and viewing another encrypted one. As you know, the rules here do not allow issues related to encryption, so I will not proceed with anything other than what I have already written ...
If you record an encrypted channel using your smart cam C.I. and smartcam, it’s normal you can’t decrypt two channels at the time: it’s a limit of C.I. modules
ok, I thought it would work the same way as on another receiver I have that use a built in encryption (conax), there I can record one channel and watch another one. But this is not possible when using a C.I then. Thanks for the explanation
It's a limit of C.I. modules, not of decoders, as far as I know.
Only professional C.I. modules allow multiple viewing/recording.
Obviously, we are talking only about official and legal ways to use smartcards, that's by their own C.I. smartcam module... ;)
