Hi
I have a problem when i try to use both tuner at the same time with my vu+ solo SE and the blackhole image
When i record a channel with tuner A, i get a black screen with all other channels with tuner B
I have a twin LNB with 2 output and 2 cables are connected to the solo SE tuner A and tuner B
LNB1: Hotbird (13°E)
LNB2: Astra (19,2°E)
The tuner A is well configured (Diseq A/B, port A: Hotbird, port B: Astra...)
Tuner B = Tuner A
All channels are working (Astra & Hotbird)
I tested separately with only one cable on tuner A then on tuner B, everything is OK
Before switching to the solo SE i have had the same problem with my Vu+ Duo...
I tested with Blackhole 2.1.7 and 3.0.1
I don't remember which version exactly but i have not encountered this issue with oldest version of BH image
I don't have this issue with the VTI 8.2.3 image with the same tuner's configuration
I prefer the BlackHole image so...if someone have the solution ;-)
Thanks
Tuner B = Tuner A
Thanks
