Two Vu+ boxes same room single remote, is it possible?
ikklepaul
Hi,
I posted this in the blackhole section but things its more a generic qustion so posted here
Basically I've got two vu boxes in the same room a vu+ duo and a vu+ solo2
Ive managed to get the Universal Vu Solo+ Remote to work with my telly by changing the code to 2448
Ive also made sure the solo 2 remote is set on mode 2 which is meant to be the default as per the manual.
Mode 1 : SOLO / DUO
Mode 2 : UNO / Ultimo / SOLO2 / DUO2
Mode 3 & 4 : reserved for future models.
Press <<2 + 7>>, <HELP>, <0001 or 0002 or 0003 or 0004>
The issue I'm having is that when i use the universal remote its changing channels on both boxes.
Is it possible to have the solo 2 remote just control that box and the original duo remote control just control the duo.
Also if I use the original duo remote it only controls the duo.
I have tried changing the mode on the solo2 to 3 and 4 along with setting the remote, but it makes no difference if I use the universal remote it still controls both boxes.
