Request TXT Subtitles display wrap
Tony il Capo
Hi
Recently you guys added the autolanguage and subtitle options to the Black Hole images, it would be possible to add an option to wrap teletext subtitles? - make Teletext subtiles use full lines on screen-
Like they are now sometimes they show up to four or more lines, with only three or four words in each line, that looks stupid, in my other box running Enigma2 I have the option to "wrap" subtitles and they look great, it makes full subtitle lines making them in 1 or 2 lines.
I would also like to fix TXT subs in bottom, instead of floating around in screen (orignal code position).
If possible please do it.
Thanks.
What I meant was TTX subtitle (not TXT) line wrapping, make bigger subtitle lines, or subtitle lines rewrite, or smart brake TTX subs.
Make TTX subtiles lines longer so that they use only the necessary lines.
As they are by default, I see up to 4 lines of subtitles in screen, with 2 lines with only one or two words in each.
You can see this in most fta channels (if TTX avaiable) from 28ºE
:offtopic:
btw, Do openBlackHole have this option?
"Yes, open Black Hole has this option!"
No more problems with subtitles!
Looks like open Black Hole is the way to go!
Questioning and answering myself, great!:grin:
