udpxy for Ultimo 4k
cetrespeo
Hi all,
Does anyone know where could I find a udpxy compiled for our OBH for Ultimo 4K?
Thanks in advance for your support
Hi all,
I join the request, I just bought the vu + just 4K and I can not find this addons, please help.
Thank you.
I have not test.I never used it.
There is no addon
You have to install everything manually.
And make an adequate Channel list
try first with telnet
opkg install udpxy
reboot
If not try one of this , I found in my collection.
udpxy_1.0-23.8-armv71_all.ipk (is with start Up script)
It seems to be working
I have status in my web browser.Tested with BH image.But not tested with IPTV.
and udpxy_0.23+git86+c045a1e-r1_arm without .
There is no addon
opkg install udpxy
reboot
Very glad I've found how to see paid channels on my vu+4k. As simply as you did it on telnet and an update list of channels. But you maybe also modify automatic metric =1 on Internet protocol (TCP/IPv4) --> Properties --> Advanced options --> Uncheck automatic metric and Metric =1. Now works perfectly.
Very glad I've found how to see paid channels on my vu+4k. As simply as you did it on telnet and an update list of paid channels. But you maybe also could need modify automatic metric =1 on W10... Go to Network --> Properties --> Internet protocol (TCP/IPv4) --> Properties --> Advanced options --> Uncheck automatic metric, and change Metric =1. This is why paid format files as (RTP://@xxx.xxx.xxx.xxx:Port) can't be seen on your vu+ or Blackbox app in iPhone or iPad, (where you must uncheck Transcoding on Settings menu also) after you uncheck your default configuration on settings of W10, now works perfectly, in my experience. Maybe works for any other. Tested in vu+ ultimo 4k, Openspa distro. This has been very useful to me to obtain from Vu+ set-top-box the maximum performance.
Very glad I've found how to see paid channels on my vu+4k. As simply as you did it on telnet and an update list of paid channels. But you maybe also could need modify automatic metric =1 on W10... Go to Network --> Properties --> Internet protocol (TCP/IPv4) --> Properties --> Advanced options --> Uncheck automatic metric, and change Metric =1. This is why paid format files as (RTP://@xxx.xxx.xxx.xxx:port) can't be seen on your vu+ or Blackbox app in iPhone or iPad, (where you must uncheck Transcoding on Settings menu also) after you uncheck your default configuration on settings of W10, now works perfectly, in my experience. Maybe works for any other. Tested in vu+ ultimo 4k, Openspa distro. This has been very useful to me to obtain from Vu+ set-top-box the maximum performance.
Abot what kind of paid channels you write here?
Legal or illegal ?
Legal or illegal ?
I do legal use from a paid set-top-box. I use this command using a vu+4k ultimo as a secondary set-top-box to watch tv from my router. Anything you can record from your vu+4k can be seen again with no restrictions or protection, but many YouTube videos direct from some paid channels are rejected once uploaded at few days, author permission is detected and can't be seen anything. I think all is legal.
I have FTA UDP streams from my IPTV Provider
and used the second attachment IPK and already have start script and plugin from mips based receivers
working flawlessly on ZERO 4K with blazing speed
anyone need help i can post step by step process
Plz help to run it on my solo 4k
thanks
Good morning,
please see if you can pass me the process step by step as you did in Vu + zero 4k receiver, I am not able to work.
Thank you!
