tobler
Little prob, the ui screen setup plugin doesn't works
ok, it LOOKS as working if not used or just for a fast test, but is enough try it for a good reason (have a smaller ui for some tv probs) that clearly it doesn't works as it created for (move and resize the osd screen: jus the vertical setup is near to work, the horizontal one is far from it)
i looked in the board many times but apparently NO-ONE noticed that, but for sure is not only my duo with that prob
if no one noticed it, the prob is only mine (i doubt it) or no1 need that plugin
so, in the case just me use that one, instead fix the setup gui , is there any way for send values and test they without use the buggy move&resize interface?
i post here because that plugin is embedded in the image and i think is present in all the vu+ versions
the duo is really a good dev, thx to the vu+ and the bh team
