Un foreseen problem on vu+ duo2
Abb
I just bought the obove from Germany to my surprise I found it had 2 twin plug gable tuners ,not the usual screw type where lnb cable is attached ,is there a blug which I can use or do I have to change the tuner to a screw on ,I hope I am in the right place and I hpoe my post is making any sense. Thanks for any help.
it sounds like you have order box with incorrect tuners,
the Vu Duo 2 is aavailable in different tuner configurations,
DVB-C/T
DVB-S2
or mix of.
You will need to purchase additional tuner or request from supplier swap over existing tuner to correct one
Good Luck
  • Like
Reactions: Abb
DVB-C/T
DVB-S2
or mix of.
Thank you Hamish for your reply do you know a code or a number which these tuners have, I ve seen some on the web which are original ones and are they easy to mount them? Again thanks for your help
Good Luck
