unable to flash ... help please
Knuppa
Am I doing somting wrong ??
1: first uppdated the bootloader..
2: Formatet and copyed vuplus folder to the usb.
3: Restarted the VU +Uno wit usb in the usb slot.
4: Pressed CH- at boot, but it did not start the uppgrade...
5: tryed the FPGA plugin, but witch file am I going to use.???? There are 4 files in the dir ..bootxxx, rootxxx, kernelxxxx and splashxxx
regads
knuppa
Try a different brand of Usb stick, as I had the same problem. I tried a different (brand) usb stick and it worked, first time all of the time. Hope this helps
