Vu+ Solo 2, Image 3.0
Unable to record multiple channels, unable to view other channels while recording
The technician tried to install a motorized satellite but couldn't make it work. I had an old software version at the time.
Because of that he installed a Toneburst A/B on tuner A (port A: hotbird13.0E, port B: astra19.2E),
tuner B: nothing.
I should be able to record up to 8 channels simultaneously and view any other channel, right?
I am only able to record a single channel and I am unable to view other channels while recording .....
Funnily enough it worked only once after the software upgrade and that's it.
I tried to install other software versions, no luck.
Do you think it depends on the Toneburst?
Please help.
tuner B: nothing.
Please help.
