Unicable II fix
valery84
I read that in VTI latest upgraded images, developers have fixed Unicable/jess LNB. Is there a possibility that this is also done in BH?
Great sarcasm (I don't understand it, but I am sure it is). For someone else who was interested, vti has released a fix for some issue in management of unicable II LNB. I don't know what it is, because I am BH 3.1.0 user, not vti. For examples, I noticed that if i choose dur-sat 124 uk, I can't use diseq switch, because the item doesn't appear in LNB configuration menu, but I don't know if they have fixed this issue or other things. Maybe that's why I asked?
Maybe now you finally cleared what the issue you had in your mind was? Or should we be reading into your mind?
This is a forum, not a community of wizards and if you users don't explain in a very detailed way what is your problem, you won't get any useful answers.
Two posts and no answer, but only polemics. It's your fault if you do not understand WHAT I asked, but you are only focused on WHY I have asked
