uno is crap box big problems in it
azeemmir
hi
i have bought 6 uno for family and 5 r not working scanning problem, tried diffrent images,
upgrade from plugin fpga every thing but it cant scan channels,
guy 2 boxes changed and still same problem now going to that shop again and will truogh on head of that shop keeper,
guy think 1000 times b4 buying that crap,
hi
Check non-working box in the place of the only working Vu+Uno ....
hi i have tried every thing i have bout 4 duo and ultimo is in my bedroom and 3 solo and now 6 uno and only uno have problem and all other boxes r working like charm,
and i have tried pli blackhole original img and upgrade fpga still nothing , i have called my friend in norway and he had once same problem and then he bought another brand DB, and i have google many ppl have same problem and no 1 have solution,
really tired with uno,
gr
WOW you have ALOT of dish's / lnb's and a very big house (lucky man :))
Anyhow I feel it is very unlucky (even unlikely) for you to get 5 faulty Uno's in 1 go, I think you have missed something in the setup, or have a problem somewhere else.
Have you tried using each Uno on it's own ?
Have you used the same satellite feed on each one (removed it from the working one and tried it on each non working one) ?
Have you used the same settings on each one ?
hi
thanx for reply uno's r for my family my own i have umtimo , and duo and 8000 and 800se, waiting for duo2, it will be monster,
yes i have tried all boxes 1by 1 setup is working with my 8000, and i have tried single lnb and diseq both ,
and but it tunes only 250 channels from astra2 not more,
now in evening i wil try to change lnb and diseq switches i have twin tuners in every room so in evening i iwll try in other room maybe it will help ,
i liked uno good shape and display fast but scanning is only problem, my duo is perfect,
gr
Most of my company colleagues have VUuno
and all are very very satisfied Most called it the best buy box.
I also have the uno
I do not see any problems and the difference compared to other boxes certainly not on Astra.
i have bought at least 10 UNOs for friends and colleagues and never had problems
to tell you the truth i never bothered to scan channels as i install and update channels from the 'Addons Download Manager/settings'
hi guys i have tried now with other cable and diseq still same it means problem in boxes and tried some 500 and golden m with same setup working perfect
going to shop and will trough it
hi guys 1 more development, i went to shop and tried 1 box at his shop with single lnb astra2, we scanned and it was working fine, strange i have tried diffrent cables was not working, but in his shop it was fine no wagain i am going to home and wil try with other setup, and will report
gr
Have you tried to Update the FPGA plugin from the "Plugin" menu in your UNO's ?
There is a TS_pro.dat file you need to download !
