UNO NO HDMI OUTPUT SCART OK
moustik
Hi
Since few weeks i lost the picture when using hdmi output it was working perfectly during more 1 years with a bh image.
I try with different hdmi wire ON 2 different tv i try with original image and then last BH and it only work with the scart .
The uno is still guaranti but when i send it they tell me it works fine with hdmi output.
Yesterday i connect it and it works during few hours ,but this morning still the same no hdmi scart ok .
the only thing i have done is adding my hdd on tne uno !
The fan is ok ...
Any help please
thank you
You likely have an intermittent fault.
Try changing in the AV menu the HDMI resolution settings to all the available options and see if any works.
