Uno UNO - red light
fpmfc3
Hi
I read a lot of post on this topic, but I have not found a solution
When the UNO was blocking, I would turn it OFF and ON soon, and it would restart normally.
If I turned off long (so cold UNO) it would not restart immediately
This has duration 3 months like this
Now it is completely blocked => Nothing happens
Question
- Motherboard or PSU default ?
- Motherboard => no C807 capacitor => then which to eplace ?
- PSU There are 3 "big" capacitor near the output connector C8 C9 C11
- PSU connector output only 3x12V and 3xGND
I can post photo of MB and PSU
Thanks for your help
1.check the power supply if it has any swelled cap
2. there is must be any kind bad cap in psu
u must have to check it thoroughly
thank's aliraza63 for your help
I've check the PSU connector :
on pcb marked: ground ground ground +12V +12V +12V => and I test 12,20V 12,20V 12,20V => it seems ok
Yes it seems quite ok
have u tried to flash the box with VU+ Utility ?
May be box has any bad image in flash or the image has any kind bug and not getting its 2nd boot to load the firmware ?.
If u have its nfi image file try it . Once I had the Problem with my VU+ ultimo . It was blocked accidently with no reason I had used this method . May be it will work for u also.
Here is the Inf file link .
http://archive.vuplus.com/image/2012/7.0/
VU+ Utility
