Unos Record Path
Bigfoot
Hi All,
Had my Uno 3 weeks (ACE).
My little glitch is with my External hard drive's Record Path.
I installed an Intenal Drive (Works Spot On) as did my
External Drive, worked OK before I installed the Internal drive.
My Question now is, What path do I enable to record to my
External drive over the Internal Drive.
Don't mind if the Uno record to both drive at once, just
as long as I can record to the External Drive.
My uno will play back recordings from the VLC Media Player
I recorded with the Blackhole's 1.7.2 Server Tuner on my PC
from the ExternalDrtve.
Thanks for any Help, BF.
Have you looked at menu > setup > system > recording paths ?
Also how have you got both drives mounted via devices manager ?
Hi Artorius,
The record path will not change the top line
from (Media/HDD) to (Media USB).
In Device Manager I have set Internal Drive to (Media HDD).
External USB Drive to (Media USB) also tryed External Drive in
Media USB2 and 3.
In Device Manager I may have deleted (Bookmark) blue button.
When I press OK in Device Manager to
go through to next stage it's Grayed Out.
Just can't find a way to set Record desternation as Media USB.
Thanks for you Help, BF.
1.Mount USB drive (Device manager)
2.Recording paths (in System panel)
>>OK (Select Location /Bookmark panel) >>Menu>> 1 (switch to filelist) >>search and choose USB drive >>Green (OK)
Now with remote (left,right) you can choose movie location in recording paths menu for timer,instant,default recording e.t.c
