Unwanted downgrade to 4.1.022
AlexWilMac
Moderator
Because of some issues in the last updates, for the first time since I use BH or OBH images, I decided to take advantage of the daily full backups scheduled by OBH, to get back to 022 (actually, I could have used also 023 but I had already deleted them by mistake.
The issues, as reported elsewhere, affect the Solo4K but not also the Duo2 and concern particularly:
PiP (some channels are impossible to be in PiP);
Big PiP mode, not working after 023;
Offline decoding, causing always crashes.
It's clearly possible the updates had solved other bugs but I haven't found any, so far, in 022.
So, I put the 033 in omb and we'll see the future updates ;)
