Upcoming recordings, is there a easy way to find and remove them?
boyofford
Hi all,
Upcoming recordings, is there a easy way to find and remove them? With so many channels over couple satellites its difficult to check what I have got set to record! Which is problem if start watching something and then tuner needs to change channel to record something I've forgotten about.
Sent from my HTC Sensation Z710e using Tapatalk 2
Sounds good, how do I get there?
I'm using the cooltvguide plugin for epg, and timer option just sets recording.
Timer menu is in Shutdown Menu. Long press of Shutdown key on your RC (it's default, could be short press too, depends on your setting)
I confused you, I'm really sorry:chair:. The timer I wrote above is a sleep timer. Recording timer is under Menu -> Timers.
Sorry again;).
