Update Vu+ Zero
Kantilo
Hello,
This update : Black Hole 3.0.3.I Kodi
Is for ARM Boxes only, so not compatible with Vu+ Zero ?
In this update : Black Hole 3.0.3.H Kodi
ARM is not written, so there is compatible with Vu+ Zero ?
Or i need an update without a letter and without Kodi :
Black Hole 3.0.3 Kodi ?
Thank you
Thank you, it's because i have see the update monitor, BH is already installed but an older version, for update i just put the image on my usb stick and put it on my Vu+ ?
I lost my data ?
I lost my data ?
If an ONLINE UPDATE for your box is available, you don't loose anything because you do using your image commands. You loose everything if you FLASH your box. But flashing is not equal to updating.
But all of this gets back to the main question: why did you ask for versions, ARM or not CPUs and so on? Don't read around topics that have nothing to do with your box. The only action you have to do is performing the online update using your image commands.
Thank you, but i don't remember if online update is available for my older BH, how update with usb stick if not avaible ?
You can't update by a USB stick and there is nothing to remember: just check for the presence of an update through the appropriate menu.
