Update?
del6600
I notice a new update is available - Black Hole Vu+ Duo 2.0.3 Hyperspace - Is this update ok for Vu+ Duo?
I ask this question because a lot of mention is for Solo 2.
Del
I've just flashed it and all working. Check out shiro post for backup mate as personal backups don't work with latest update
Yes I'm using next gen gradient by army 2.0.* and that works. Matrix has put 2 new smart skins on server also for download MX red diamond and Adriatic blue
Cheers M8. I have just installed a fresh version of 2.02D in Meoboot, using my own Satellite.xml settings. Just updated 10 sats still got 17 to do, now I find this new version!! Still the exercise has been well worth it. I have been using vhannibal satellite settings but using my own Satellite.xml settings I have found possibly 100's more channels over 28E-30W. I need 48 hours per day at this rate to see all there is to see. Will install 2.3 in the next few days.
Thanks for the help.
BR
