update
netguy
hi guys seems to be an update im not getting installed on my vu duo2 image open black hole im at build 0.6.010 but just one not installing any idead how to find out what one it is or can i find it anywhere cheers
If you are using obh, in openmultiboot, it will be an openmultiboot update that can not be installed (as it's in use), it is normal and there is nothing you can do about it i'm afraid.
