You need to load the new image, using your USB stick, which will overwrite ALL your current settings, and will need to be re-done, once the image is loaded.
You could back up your channel list, using dreamboxedit.
You should check that your receiver has the last released CFE, (Bootloader), update: http://www.vuplus-community.net/board/threads/vu-duo-boot-loader-updgrade.3555/
You should also be sure that your VU+ receiver is genuine, and not a clone.
