Upgrade VU+ SOLO
boukalli
Hi,
Currently i have BH 2.0.3 on my Vu+solo and i want to upgrade it to BH 2.1.0.
I want to khnow how and steps to do this.
Thanks
I am struggling with upgrading my Solo from its current Black Hole 1.7.5 to the latest. I have miserably failed although I am not technologically challenged :-(
Have you checked if your bootloader needs updating?
http://vuplus.com/downloadSoftwareUpdateContent.htm?idx=5&pagenum=1
Mick12334, thanx for directing. I have done the steps, but it is obvious that I am doing something stupid there. I will go again through the steps more carefully. Once done I will post results
Appreciate your help
Have you checked if your Solo is genuine, as there are a lot of very good clones, not good in quality, but looking very close to the genuine product?
http://vuplus.com/pressNewsContent.htm?idx=38
Mick12334; it's a clone!!!! :-( Took the cover off and compared components to the pictures in the link you provided and shit hit the fan!!! I have been had :-(
I am soooo sad :-(
You can contact VU+, to make sure, but if you're certain it's a clone then I'd complain to your supplier and whichever authority is supposed to stop these scammers.
