testing1234
Hi,
I was wondering if I can upgrade using the internet ?
I did use openpli before, and there I use the upgrade function inside software management.
But I can't find that using black hole Vu+ Duo 1.7.?
Or is it only possible to 'upgrade' using a USB (that removes everything and do a clean install)
Thanks
Thanks
