USALS
blue
Hi guys i have recently updated to new BH image 1.7.2 and since updated cannot get usals to work ? i have reflashed numerous times thinking bad flash but still the same !! Tuner A is set up on SIMPLE with my long/lat's set corr. which is obviously motor feed !! Tuner B is set up as EQUAL to A ..... i had no problems with it before flashed new image ? if i select SATFINDER in SET UP and select each sat with a valid transponder locks on no problems !! Any ideas guys pls ?
You shouldn't setup Tuner B equal to Tuner A, but loopthrough to Tuner A.
Hi buddy thank you but tried it with that config.... if your recording a particular channel you get greyed out channels which cant be viewed on that sat. position !!
If you want to be able to watch any channel while you are recording another channel, you need two antennas.
no you dont bud just a twin lnb an you would be able to record a program on the same satellite !! cheers anyway .
hmm wrong:
better to use for the B 'second cable of motorized LNB tuner A' :)
obv are needed 2 out from the lnb and 2 cables
I have bud got a twin lnb and 2 coax feeds !! TunerA coax 1 (motor) ...TunerB coax 2 (2nd feed off lnb)!!
