This without powered hub :
Linux version 3.1.1 (amedeo@meo-fisso) (gcc version 4.6.4 20120303 (prerelease) (GCC) ) #1 SMP Sat Mar 16 15:49:32 CET 2013
Fetching vars from bootloader... found 11 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
Using 512 MB + 256 MB RAM (from CFE)
Reducing DRAM0 to 256 MB; consider using BRCM_UPPER_MEMORY or HIGHMEM
bootconsole [early0] enabled
CPU revision is: 0002a044 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
bmem: adding 137 MB LINUX region at 6 MB (0x08949000@0x006b7000)
bmem: adding 112 MB RESERVED region at 144 MB (0x07000000@0x09000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00010000
On node 0 totalpages: 65536
free_area_init_node: node 0, pgdat 8065e340, node_mem_map 81000000
Normal zone: 512 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 65024 pages, LIFO batch:15
PERCPU: Embedded 7 pages/cpu @81203000 s4384 r8192 d16096 u32768
pcpu-alloc: s4384 r8192 d16096 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: bmem=112M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
Memory: 138256k/262144k available (5381k kernel code, 123888k reserved, 1141k data, 236k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 404 MHz (202.497 MHz counter)
Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
pci 0000:01:00.0: [14e4:8602] type 0 class 0x000101
PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
pci 0000:01:00.0: reg 24: [mem 0x00000000-0x00000fff]
pci 0000:01:00.0: reg 30: [mem 0x00000000-0x000007ff pref]
pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
pci 0000:01:00.0: BAR 5: set to [mem 0x10510000-0x10510fff] (PCI address [0x10510000-0x10510fff])
pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 128 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
Registering unionfs 2.5.11 (for 3.1.10)
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 270
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
sata_brcmstb 0000:01:00.0: version 4.0
brcm-pm: enabling sata clocks
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
PCI: Setting latency timer of device 0000:01:00.0 to 64
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:01:6f:fb)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
ata1: SATA link down (SStatus 4 SControl 300)
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device success with 0
blackhole initialised
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0201 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0xFF for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0xFF for chip on CS0
nand_read_bbt: Bad block at 0x00920000
nand_read_bbt: Bad block at 0x040e0000
nand_read_bbt: Bad block at 0x04120000
nand_read_bbt: Bad block at 0x07720000
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007600000 : "rootfs"
0x000007600000-0x000007a00000 : "kernel"
0x000007a00000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
ata2: SATA link down (SStatus 4 SControl 300)
UBI: max. sequence number: 3279
UBI: attached mtd0 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 118 MiB
UBI: number of good PEBs: 941
UBI: number of bad PEBs: 3
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 941
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 19/3
UBI: image sequence number: 1758929706
UBIFS: parse sync
UBI: background thread "ubi_bgt0d" started, PID 45
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 116436992 bytes (113708 KiB, 111 MiB, 917 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 236k freed
NET: Registered protocol family 10
procmk_init
dvb_bcm7335: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (bm750)
bcm7335: hotplug_callback():
Hotplug - status.connected 0
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (BCM7335 FE)...
[MPVR]: >> misc_pvr_init
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
[0;35m[CI]:[0;0m-BM750_PCB_2_1
[CI]: registered ci0
[CI]: registered ci1
[DFP]: registered dbox fp
[DFP]: bcm7335_i2c_write: Error 1114113
[DFP]: bcm7335_max_i2c_write: Error 1114113
[DFP]: Scart 4707 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
udevd (116): /proc/116/oom_adj is deprecated, please use /proc/116/oom_score_adj instead.
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
Empty flash at 0x000001ec ends at 0x00000800
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
Installing knfsd (copyright (C) 1996
okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
[CI]:ci_dev_open
[CI]:Opening A GPIO's for 7335 platform
[CI]:Opening A GPIO's for 7335 platform....done
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:Opening B GPIO's for 7335 platform
[CI]:Opening B GPIO's for 7335 platform....done
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[CI]:NEXUS_Remux_Start
[CI]:>>close_mpod tuner:0
[CI]:remux stop
[CI]:get_remux_startcnt() count : 1
[CI]:>>close_mpod tuner:1
[CI]:remux stop
[CI]:get_remux_startcnt() count : 0
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -2031329816
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -200, right volume -200
[AUD]: AUDIO_SET_MIXER : amixl 41, amixr 41
[AUD]: AUDIO_SET_MIXER : next left volume -3128, right volume -3128
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xf
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
FE tune
Module Size Used by Tainted: P
nfsd 99914 11
exportfs 3976 1 nfsd
ext2 56552 0
brcmfb 1127 2
dvb_bcm7335 4943914 2 brcmfb
procmk 1397 1 dvb_bcm7335
ipv6 340100 12
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 3.01
S: Manufacturer=Linux 3.1.1 ohci_hcd
S: Product=Broadcom STB OHCI
S: SerialNumber=ohci_hcd
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 3.01
S: Manufacturer=Linux 3.1.1 ehci_hcd
S: Product=Broadcom STB EHCI
S: SerialNumber=ehci_hcd
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
NIM Socket 0:
Type: DVB-S2
Name: BCM7335 DVB-S2 NIM (internal)
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
