root@bm750:~# lsusb
Bus 001 Device 002: ID 0951:1607
Bus 001 Device 003: ID 15a4:9016
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0001
Bus 004 Device 001: ID 1d6b:0001
I've seen your dmesg but it's correct without errors.
I can only suppose there is some problems around your power supply for USB devices and your dual tuner device needs more power to work properly.
Try with a pwoered hub USB. I haven't a device with your specs but I've two devices with same hardware (single tuner). I can try with them if all works correctly for some time.
I borrowed a USB hub powered by AC Adapter but the results is the same.
The USB tuner still failed after some zapping. No image until reboot.
I just wondered if you can make a script that can unload the modules, stop the usbtuner and start them all again. This way I can execute this script, so the wait time to start the tuner will be less that waiting to reboot the vu+ duo.
