USB DVB-T2 issue
David Hornsby
Hi,
I have a "Foxnovo® DVB-T USB TV RTL-SDR FM+DAB Radio Tuner Receiver Stick Realtek RTL2832U+R820T" that I want to set up on My Solo2 running BH 3.0.1.
The stick seems to install as it appears in my list of tuners. It is enabled and I have set it up for my region in the settings.
When I try to scan with the tuner it comes back with an error "failed to start scan".
I used the method on your forum to generate an output.txt file. Find attached.
However I think I wasn't able to capture all the data -
When I entered "cat /proc/bus/usb/devices >> /tmp/output.txt" it retuned "can't open '/proc/bus/usb/devices': No such file or directory".
Hope you can help?
Hi,
Hope you can help?
http://www.vuplus-community.net/boa...images-debug-script-per-le-immagini-bh.21512/
