USB Ethernet adaptor
ocig
My Ethernet port is broken and do I'd like to use a USB Ethernet adaptor with chipset ax88179. How can install it?
do you think that it's possible to install the USB Ethernet adaptor?
(I've decided to downgrade the BH image; now I'm using the 2.1.4 )
I usually compile drivers only for latest BH images.
I'll verify this weekend if I've all the needed stuff to compile the driver you need.
