usb recording problem
gh_n
hi friends
with vu+solo
i have a problem on recording films to usb
use 16 gb usb stick
i mount from device manager to media/usb
but when want to record gut this massage
(no hdd found or hdd not initialized)
with other images worked grate but with BH dosn,t work
i dont no about bh images
could some1 please help me what is the procedure ?
thanks
hi friends
with vu+solo
use 16 gb usb stick
thanks
You have to setup the right recording path.
To do it, first you have to enable expert mode in Customize menu:
Menu > Setup > Sytem > Customize > Setup Mode: Expert
Then you will be able to select the recording path:
Menu > Setup > Sytem > Recording Path
