USB stick excludes on/off switching
Ruudi
After USB stick mapping for picons (media/usb/picon) not possible to turn the box on from idle mode. Only "hard" reset by rear switch helps to turn it on. How to "harmonize" the box to work with USB stick?
Image in STB? BlackHole or Open BlackHole?
Crash Log ?
Usb Stick 2.0 0r 3.0?
Image Black Hole 2.1.7, USB stick 2.0, Crash Log - can't say.
Crash Log where?
You can find it at ( Ftp to your STB ):
/home/root ( folder )
or
/media/hdd (root folder of your HDD)
Note: I've looked at your history posts, and you said that i have recommend you to remove lcd4linux ... can you point me the right direction post?
About lcd4linux. Appparently you did not understand my wording correctly. You recommended to instal the lcd4config file, not to remove this!! I removed it by another member recommendation http://www.vuplus-community.net/board/threads/flashing-circle.27866/. LCD screen is OK now and this topic is forgotten.
Excuse me ... but i don´t understand ... in your post --> http://www.vuplus-community.net/board/threads/flashing-circle.27866/#post-206231 you said that i recommended to remove LCD4LINUX plugin ... and i don´t remember that ... afaik ... never told that to anyone. Probably i could said to uninstall and install newly, and perhaps to handle my lcd4config configuration file, but never to remove ( it´s not a solution ), at least for me.
Nunigaia, I kindly ask you let's forget the theme! You have never asked me to remove the LCD4LINUX! Anothe member did. I was enraptured over your lcd4config file about what I expressed gratitude http://www.vuplus-community.net/board/threads/duo2-lcd4linux-lcd-display-layouts.13520/page-20. But the config file (lcd4config) caused problems in the box operation so I uninstalled it for time being. I will try to instal it back later.
About the present thread I give feedback tomorrow.
Let's move ahead in a friendly way!:)
No problem, you are welcome :)
Crash Log where?
or
/home/root folder - emty;
/media/hdd - no Crash Logs of late. The last one of 5 March.
