I have 2 usb sticks my duo 2 will not recognise none of them one is 32 gb and the other is 16 gb can any bodat recommend one please will I be beter off with a smaller gb usb stick
Let's start from the beginning.I take it you have formatted your usb stick using A:Blackhole apps/usb format wizard ? or B:Another format program?Then go to Blackhole apps/Device manager and you'll see what devices are recognised.Press Red to change mount point then scroll right to /media/usb.Press red to save then restart enigma.When you go back to Blackhole device manager it should now be mounted.
