USB Tuner: AF9035 devices
angelofsky1980
BlackHole Driver Specialist
Reference driver: Avermedia AverTV Volar HD (A835)
Driver Name: af9035
Here is a list of possible compatible devices with the mentioned driver. Please test it and report if works or not.
Afatech AF9035 DVB-T USB2.0 stick
Avermedia AverTV Volar HD (A835) [OK]
Avermedia TV Volar Green HD [OK]
Avermedia TwinStar
TerraTec Cinergy T Stick
Yarda
Does anybody have Aver TwinStar (A825) and can confirm, that its fully working? (both tuners (1 program recording and another watching?)). Thanks a lot.
stick50jr
I have an Avermedia Twinstar and I tried BH 1.6.7 beta. Unfortunately it was not detected automatically. I'm currently using Vix 2.3.133 with the ItalySatDTT plugin to provide drivers. This is working very well with both tuners (C & D) providing HD terrestrial simultaneous recordings etc. I'm away from home over Christmas, but will try the latest beta or better when I get back in the New Year. Maybe it will get detected with the later versions of the beta.
angelofsky1980
We are working to re-implement all previous supported drivers.
fdgexe
ahh ok, credi che ci vuole molto lavoro per essere implementato??? l'ultima immagine è veramente super complimenti a tutti, ma senza il supporto di questo tuner sono costretto a rimettere la 1.6.6 (che è cmq un ottima img) dove funziona bene
angelofsky1980
Mi serve qualche giorno per tornare sul pezzo dopo quasi 10 giorni di ferie :)
angelofsky1980
Dear angelofsky1980 do you made any progress with the driver compatibility and the 1.7.0??? Thank you!
I've some bugfixes on the USB DVB implementation to be solved prior to implement new drivers ...
Into some 2 or 3 days I can work around new drivers implementation...
angelofsky1980
Vu+Duo IPK for AF9035 devices on BH 1.7.0.
Installation instructions:
1. upload the IPKs attached to this post into your /tmp box folder via FTP
2. remove the current A867 driver with
ipkg remove kernel-module-dvb-a867 --force-depends
3. install all the ipks posted here with
ipkg install /tmp/*.ipk
4. connect your device
5. execute these two commands
depmod
depmod.26
6. reboot your box
  • kernel-module-tua9001_3.1.1-r5_bm750.ipk
  • kernel-module-af9033_3.1.1-r5_bm750.ipk
  • kernel-module-dvb-usb-af9035_3.1.1-r5_bm750.ipk
angelofsky1980
Vu+Solo IPK for AF9035 devices on BH 1.7.0.
Installation instructions into Vu+Duo post!
  • kernel-module-tua9001_3.1.1-r5_vusolo.ipk
  • kernel-module-af9033_3.1.1-r5_vusolo.ipk
  • kernel-module-dvb-usb-af9035_3.1.1-r5_vusolo.ipk
angelofsky1980
Vu+Uno IPK for AF9035 devices on BH 1.7.0.
  • kernel-module-tua9001_3.1.1-r6_vuuno.ipk
  • kernel-module-af9033_3.1.1-r6_vuuno.ipk
  • kernel-module-dvb-usb-af9035_3.1.1-r6_vuuno.ipk
angelofsky1980
Vu+Ultimo IPK for AF9035 devices on BH 1.7.0.
  • kernel-module-tua9001_3.1.1-r6_vuultimo.ipk
  • kernel-module-af9033_3.1.1-r6_vuultimo.ipk
  • kernel-module-dvb-usb-af9035_3.1.1-r6_vuultimo.ipk
