USB Tuner: AS102 devices
angelofsky1980
BlackHole Driver Specialist
Reference driver: Pinnacle PCTV 74e
Driver Name: as102
Here is a list of possible compatible devices with the mentioned driver. Please test it and report if works or not.
Abilis Systems DVB-Titan
PCTV Systems picoStick (74e) [OK]
Elgato EyeTV DTT Deluxe [OK]
SKY Italia Digital Key [OK]
betaone
Hi friends,
SKY Italia Digital Key (AS102 device)
is in "working" with this driver but the channel search is not successful end. Zero channels found!! :(
Has anyone had the same problem?
Solutions??
My decoder is: Vu+ Solo with Blackhole image 1.4.2
angelofsky1980
Hi friends,
Solutions??
Have you setted the correct tuner settings into Europe DVB-T?
If you have a pendrive or hard disk connected to your box, post the file usbtuner0.log. You can find it into /mnt/usb or /mnt/hdd.
betaone
Hi angel,
Yeah, i've setted the tuner setting into Europe DVB-T and i've an hard disk connected to one of usb port.
This is the usbtuner0.log :
Tue Jan 25 00:12:35 2011: USBTuner v0.2.9 started...
Tue Jan 25 00:12:35 2011: Pid of current process 874
Tue Jan 25 00:12:35 2011: Log file in use: /media/hdd/usbtuner0.log
Tue Jan 25 00:12:35 2011: Started in background mode...
Tue Jan 25 00:12:35 2011: PID of child process: 879
Tue Jan 25 00:12:35 2011: Box in use: dm500hd
Tue Jan 25 00:12:35 2011: Video Delay: n/a --- Audio Delay: n/a
Tue Jan 25 00:12:35 2011: Open device /dev/dvb/adapter1/frontend0
Tue Jan 25 00:12:35 2011: Device Name: SKY Italia Digital Key
Tue Jan 25 00:12:36 2011: open device /dev/misc/vtuner0
Tue Jan 25 00:12:46 2011: USBTuner v0.2.9 started...
Tue Jan 25 00:12:46 2011: Pid of current process 906
Tue Jan 25 00:12:46 2011: Log file in use: /media/hdd/usbtuner0.log
Tue Jan 25 00:12:46 2011: Started in background mode...
Tue Jan 25 00:12:46 2011: PID of child process: 907
Tue Jan 25 00:12:46 2011: Box in use: dm500hd
Tue Jan 25 00:12:46 2011: Video Delay: n/a --- Audio Delay: n/a
Tue Jan 25 00:12:46 2011: Open device /dev/dvb/adapter1/frontend0
Tue Jan 25 00:12:46 2011: Device Name: SKY Italia Digital Key
Tue Jan 25 00:12:46 2011: open device /dev/misc/vtuner0
Tue Jan 25 07:15:45 2011: USBTuner v0.2.9 started...
Tue Jan 25 07:15:45 2011: Pid of current process 683
Tue Jan 25 07:15:45 2011: Log file in use: /media/hdd/usbtuner0.log
Tue Jan 25 07:15:45 2011: Started in background mode...
Tue Jan 25 07:15:45 2011: PID of child process: 685
Tue Jan 25 07:15:45 2011: Box in use: dm500hd
Tue Jan 25 07:15:45 2011: Video Delay: n/a --- Audio Delay: n/a
Tue Jan 25 07:15:45 2011: Open device /dev/dvb/adapter1/frontend0
Tue Jan 25 07:15:46 2011: Device Name: SKY Italia Digital Key
Tue Jan 25 07:15:46 2011: open device /dev/misc/vtuner0
Wed Jan 26 00:24:12 2011: USBTuner v0.2.9 started...
Wed Jan 26 00:24:12 2011: Pid of current process 29639
Wed Jan 26 00:24:12 2011: Log file in use: /media/hdd/usbtuner0.log
Wed Jan 26 00:24:12 2011: Started in background mode...
Wed Jan 26 00:24:12 2011: PID of child process: 29641
Wed Jan 26 00:24:12 2011: Box in use: dm500hd
Wed Jan 26 00:24:12 2011: Video Delay: n/a --- Audio Delay: n/a
Wed Jan 26 00:24:12 2011: Open device /dev/dvb/adapter1/frontend0
Wed Jan 26 00:24:12 2011: Device Name: SKY Italia Digital Key
Wed Jan 26 00:24:12 2011: open device /dev/misc/vtuner0
Wed Jan 26 07:19:47 2011: USBTuner v0.2.9 started...
Wed Jan 26 07:19:48 2011: Pid of current process 655
Wed Jan 26 07:19:48 2011: Log file in use: /media/hdd/usbtuner0.log
Wed Jan 26 07:19:48 2011: Started in background mode...
Wed Jan 26 07:19:48 2011: PID of child process: 658
Wed Jan 26 07:19:48 2011: Box in use: dm500hd
Wed Jan 26 07:19:48 2011: Video Delay: n/a --- Audio Delay: n/a
Wed Jan 26 07:19:48 2011: Open device /dev/dvb/adapter1/frontend0
Wed Jan 26 07:19:48 2011: failed to open frontend
betaone
I correct what I said earlier....
...Blackhole image is not the 1.4.3.....but it's the 1.4.2.
Tonight, i'll try to upload the new Blackhole 1.4.4 image hoping the problem will be solved.
betaone
I've installed Blackhole 1.4.4 image on my Vu+ Solo,
Sky DDT Key is in "working" ......but channels founds are "0".
Has anyone a solution?
Thank's
jarosyl
Driver Name: as102
Thank you for the excellent work - Black Hole 1.5 Multituner! But I have a problem with the USB tuner DVB-T PCTV Systems picoStick (74e).
In Black Hole 1.4.6 usbtuner 0.2.9 work properly.
In Black Hole 1.5 Multituner usbtuner 0.3.2 is problem. After installing the drivers tuner is not recognized.
Please, solve this problem.
log
Sat Apr 16 09:40:25 2011: USBTuner v0.3.2 started...
Sat Apr 16 09:40:25 2011: Pid of current process 1347
Sat Apr 16 09:40:25 2011: Log file in use: /media/hdd/usbtuner.log
Sat Apr 16 09:40:25 2011: Started in background mode...
Sat Apr 16 09:40:25 2011: PID of child process: 1350
Sat Apr 16 09:40:25 2011: No adapers to load
dmesg
as10x_usb: device has been detected
as10x_usb: fimrware: as102_data1_st.hex loaded with success
[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0
as10x_usb: fimrware: as102_data2_st.hex loaded with success
usbcore: registered new driver Abilis Systems as10x usb driver
angelofsky1980
log
dmesg
What box do you use?
I can make tests around your device: I have bought one one or two months ago :)
jarosyl
My box is Vu+Duo, stick Pinnacle PCTV Systems picoStick (74e).
In Black Hole 1.5 Multituner for usbtuner 0.2.9 and drivers Release Date: 2011-01-15 work properly.
bojja
Today arrived my new PCTV picoStick 74e with driver as 102.On BH latest image 1.6.7,this tuner is giving me (Dummy tuner)-Not Supported,I went for the BH 1.6.6,i found the driver from the blue panel of the image..installed and still with the same result of Dummy tuner).Sorry to tell you but i don't know how to do dsmeg to give more results.
angelofsky1980
Very strange.
I will check this afternoon...
angelofsky1980
I've sted my PCTV 74e and works properly.
Post here the content of /proc/bus/usb/devices and a dmesg output after you restarted your box.
bojja
Is this that we need?:
Vuplus 2.1.0 + BlackHole 1.6.6 vuuno
vuuno login: root
root@vuuno:~# cat /proc/bus/usb/devices
T:  Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
B:  Alloc=  0/900 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=0000 ProdID=0000 Rev= 2.06
S:  Manufacturer=Linux 2.6.18-7.3 ohci_hcd
S:  Product=BRCM OHCI
S:  SerialNumber=ohci-brcm
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=  2 Ivl=255ms
T:  Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 2
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
S:  Manufacturer=Linux 2.6.18-7.3 ehci_hcd
S:  Product=BRCM EHCI
S:  SerialNumber=ehci-brcm
E:  Ad=81(I) Atr=03(Int.) MxPS=  2 Ivl=256ms
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 2
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480 MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=03f0 ProdID=5307 Rev=11.00
S:  Manufacturer=HP
S:  Product=v165w
S:  SerialNumber=AA04012700008469
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:  If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=31875us
T:  Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#=  4 Spd=480 MxCh= 0
D:  Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs=  1
P:  Vendor=2013 ProdID=0246 Rev= 1.00
S:  Manufacturer=PCTV Systems
S:  Product=PCTV 74e
S:  SerialNumber=0000000M9C11LC3
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=300mA
I:  If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=Abilis Systems as10x usb driver
E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
root@vuuno:~#
Thanks very much for your help angelofsky
