usb tuner config file(s)?
cowpowah
Hi,
Where are located the file(s) containing the frequencies for the DVB-t tuner(s)?
I found a terrestrial.xml but it is for the scan. Once the transponders frequencies are found, where are they stored? Is it possible to add/edit them without scanning?
Any chances of having a bargraph (strengh & quality) for DVB-T, like the sat pointer?
Regards.
PS: congrats to the whole BH team for his work!
Hi,
Regards.
The frequencies are stored into Settings.
I think you can add/edit your settings using DreamboxEdit or other E2 setting editor :)
Thank you for your help.
Using DreamboxEdit and DreamsetEditor, I can see the frequencies and settings but I can't edit them, when I try it leads to a crash or weird behaviour of the editors...
I think I found where are actually stored the services: in etc/enigma2/lamedb, just like the sat ones.
But I don't understand the syntax, it looks like this for each service:
France 2
p:GR1,f:40
0201:00c00000:0004:0085:1:0
(France2 is the service, GR1 the transponder, that's all I can tell...)
Anyway, I managed to (partly) solve my problem (shift of 166kHz of every frequency) by tweaking etc/tuxbox/terrestrial.xml
<transponder centre_frequency="xxx166000" ... />
Unfortunatly, it's still missing a lot of services/transponders (when not all transponders!), when TV and computer get them all... :(
I know the Vu+ is very picky on signal level and quality, I had the same problem with my sat dish, I'm gonna get an amplifier for my antenna and see what happen...
bye!
