USB Tuner: DIB0700 devices
angelofsky1980
BlackHole Driver Specialist
Reference driver: Hauppauge WinTV Nova-T Stick
Driver Name: dib0700
Here is a list of possible compatible devices with the mentioned driver. Please test it and report if works or not.
ASUS My Cinema U3000 Mini DVBT Tuner
ASUS My Cinema U3100 Mini DVBT Tuner
AVerMedia AVerTV DVB-T Express
AVerMedia AVerTV DVB-T Volar
AverMedia Volar A808 [OK]
Artec T14BR DVB-T
Asus My Cinema-U3000Hybrid
Compro Videomate U500
DiBcom STK7070P reference design
DiBcom STK7070PD reference design
DiBcom STK7700D reference design
DiBcom STK7700P reference design
DiBcom STK7770P reference design
DiBcom STK807xP reference design
DiBcom STK807xPVR reference design
DiBcom STK8096GP reference design
Elgato EyeTV DTT [OK]
Elgato EyeTV Diversity
Elgato EyeTV Dtt Dlx PD378S
Emtec S810 [OK]
EvolutePC TVWay+
Gigabyte U7000
Gigabyte U8000-RH
Hauppauge ATSC MiniCard (B200)
Hauppauge ATSC MiniCard (B210)
Hauppauge Nova-T 500 Dual DVB-T
Hauppauge Nova-T MyTV.t
Hauppauge Nova-T Stick [OK]
Hauppauge Nova-T Stick HD [OK]
Hauppauge Nova-TD Stick (52009) [OK]
Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity
Hauppauge Nova-TD-500 (84xxx)
Leadtek WinFast DTV Dongle [OK]
Leadtek WinFast DTV Dongle H
Leadtek Winfast DTV Dongle (STK7700P based)
Pinnacle Expresscard 320cx
Pinnacle PCTV 2000e
Pinnacle PCTV 282e
Pinnacle PCTV 340e HD Pro USB Stick [OK]
Pinnacle PCTV 72e [OK]
Pinnacle PCTV 73A
Pinnacle PCTV 73e [OK]
Pinnacle PCTV 73e SE
Pinnacle PCTV DVB-T Flash Stick
Pinnacle PCTV Dual DVB-T Diversity Stick
Pinnacle PCTV HD Pro USB Stick
Pinnacle PCTV HD USB Stick
Prolink Pixelview SBTVD
Sony PlayTV
TechniSat AirStar TeleStick 2 [OK]
Terratec Cinergy DT USB XS Diversity/ T5 [OK]
Terratec Cinergy DT XS Diversity
Terratec Cinergy HT Express
Terratec Cinergy HT USB XE
Terratec Cinergy T Express
Terratec Cinergy T USB XXS (HD)/ T3
Uniwill STK7700P based (Hama and others)
YUAN High-Tech DiBcom STK7700D
YUAN High-Tech MC770
YUAN High-Tech STK7700D
YUAN High-Tech STK7700PH
Yuan EC372S
Yuan PD378S
Dutchsat
BH Lover
Can report that Terratec Cinergy DT USB XS Diversity/ T5 works 100%, this is a dual tuner stick, and it works fabulous, both tuners are activated, recordings perfect, I have now a 4 tuner VU+ duo. Only 2 seconds lipsync problems. Many Many Many Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
angelofsky1980
I will add a note for ALL dual tuners:
The tuner D is actually unavaiable and it's not be used. It's been created to perform a regular boot of the box.
I am very happy that your stick works correctly (with tuner C of course) :D
Dutchsat
BH Lover
Thanks. Yes I am very lucky with this stick. Indeed, the tuner D is not activated, but still it is the best stick I have tested until now. I have heard that in a few weeks VU+ will release new drivers concerning the lip-sync problems with the USB sticks. Then we have a super box with a super image!!!
angelofsky1980
Thanks. Yes I am very lucky with this stick (bought in november 2009). I have heard that in a few weeks VU+ will release new drivers concerning the lip-sync problems with the USB sticks. Then we have a super box with a super image!!!
Thanks for your info :)
Dutchsat
BH Lover
According to the specs on the german part of Terratec, http://www.terratec.net/en/products/technical-data/produkte_technische_daten_en_57350.html, The Terratec Cinergy DT USB XS Diversity/ T5 is a Combo Stick, DVB-T und DVB-C. I don't have cable, so I cannot test this function.
It is very strange, on the box of this device I cannot find anything about this, on the english part nothing is mentioned about this. I will check this evening if this option is selectable in the tuner panel, but i'am very sceptic.
angelofsky1980
When I have a lot of time I will try to implement the DVB-C for these devices already supported.
Thanks for infos and specs.
dvb4fun
Elgato EyeTV DTT work 100% ...!
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0fd9 ProdID=0021 Rev= 1.00
S: Manufacturer=Elgato
S: Product=EyeTV DTT
S: SerialNumber=005
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_dib0700
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=125us
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Regards, d4f
SatDreamer
Hello there, nice to see you here! I connected a Hauppauge Nova-T Stick to the VU+ Duo (with earlier 1.3.3F BH image) but the DVB-T tuner was not found.
Is it possible to download the driver and install it off-line? There is no internet connection to my VU+ Duo. -Thanks.
angelofsky1980
In this Board we discuss BH Images from 1.3.6 and other new versions.
It is not possible to upload the driver outside the server, I'm sorry.
SatDreamer
O
Ok, thanks. So, if I install via USB the latest BH image I can find here, it should be ok, right? Thanks again for your work.
edit: or isn't the USB driver included in the image, and I have to connect the VU+ on-line to install it?
angelofsky1980
I connected it, found the driver immediately and it works great. I hope you could add off-line install support in the future. Thanks!
At the moment the offline download method is not implemented.
The online method is very useful to distribuite to all users the last version of drivers and tools needed for DVB USB tuners without the need to publish it into a forum with the risk to create more confusion.
