USB Tuner: EM28XX devices
angelofsky1980
BlackHole Driver Specialist
Reference driver: Terratec Hybrid XS (em2882)
Driver Name: em28xx
Here is a list of possible compatible devices with the mentioned driver. Please test it and report if works or not.
AMD ATI TV Wonder HD 600
Actionmaster/LinXcel/Digitus VC211A
Compro VideoMate ForYou/Stereo
Compro, VideoMate U3
D-Link DUB-T210 TV Tuner
DNT DA2 Hybrid
Dikom DK300
EM2710/EM2750/EM2751 webcam grabber
EM2860/SAA711X Reference Design
EM2860/TVP5150 Reference Design
Easy Cap Capture DC-60
Empire dual TV
Evga inDtube
Gadmei TVR200
Gadmei UTV310
Gadmei UTV330
Gadmei UTV330+
Hauppauge WinTV HVR 850
Hauppauge WinTV HVR 900
Hauppauge WinTV HVR 900 (R2)
Hauppauge WinTV HVR 950
Hauppauge WinTV USB 2
Hercules Smart TV USB 2.0
Huaqi DLCW-130
IO-DATA GV-MVP/SZ
KWorld ATSC 315U HDTV TV Box
KWorld DVB-T 305U
KWorld DVB-T 310U
KWorld PVRTV 300U
Kaiomy TVnPC U2
Kworld 350 U DVB-T
Kworld 355 U DVB-T
Kworld PVR TV 2800 RF
Kworld PlusTV HD Hybrid 330
Kworld USB2800
Kworld VS-DVB-T 323UR
Leadtek Winfast USB II
Leadtek Winfast USB II Deluxe
MSI DigiVox A/D
MSI DigiVox A/D II
MSI VOX USB 2.0
NetGMBH Cam
Pinnacle Dazzle DVC 90/100/101/107 / Kaiser Baas Video to DVD maker
Pinnacle Hybrid Pro
Pinnacle Hybrid Pro (330e)
Pinnacle PCTV DVB-T
Pinnacle PCTV HD Pro Stick
Pinnacle PCTV USB 2
Pinnacle PCTV USB 2 (Philips FM1216ME)
Pixelview PlayTV Box 4 USB 2.0
Plextor ConvertX PX-TV100U
Reddo DVB-C USB TV Box
SIIG AVTuner-PVR / Pixelview Prolink PlayTV USB 2.0
Silvercrest Webcam 1.3mpix
Supercomp USB 2.0 TV
Terratec AV350
Terratec Cinergy 200 USB
Terratec Cinergy 250 USB
Terratec Cinergy A Hybrid XS
Terratec Cinergy T XS
Terratec Cinergy T XS (MT2060)
Terratec Grabby
Terratec Hybrid XS
Terratec Hybrid XS (em2882) [in testing]
Terratec Hybrid XS Secam
Terratec Prodigy XS
Typhoon DVD Maker
Unknown EM2750/28xx video grabber
Unknown EM2800 video grabber
Usbgear VD204v9
V-Gear PocketTV
Videology 20K14XUSB USB2.0
Yakumo MovieMixer
eMPIA Technology, Inc. GrabBeeX+ Video Encoder
to see if there are people who have these usb and can test them to move forward in the compatible list. would be big news, besides that it also would open the range to choose a new purchase.
thx
angelofsky1980
For Terratec Hybrid XS it says is testing. I cannot activate this driver with this stick. When I activate first Dib0700 drivers, then activate dib0700, first tuner works, second tuner nut supported according to the driver. Only then I can install the hybrid driver and enable, but tuners doesn't working after reboot.
Is this driver in progress or should we post log files for this?
Another user in the Italian section has tested the Terratec Hybrid XS device and I've acquired the lsmod output and the dmesg output.
The problem is the driver order procedure.
If you have a different device, you can post the output of dmesg command.
Same result with new driver, cannot enable driver when dib0700 driver is not enabled, and then I get error : device is not supported. When dib0700 enabled device is supported with the new driver.
but, looks like the device is then after rebooting in a loop, device is working according to USB tuner panel, but no tuner output however and system is very slow, the next output from dmesg:
vtuner_read_snr msg ack timeout
vtuner_read_signal_strength msg ack timeout
vtuner_set_voltage msg ack timeout
vtuner_read_status msg ack timeout
vtuner_read_ber msg ack timeout
"IN angelofsky WE TRUST" :notworthy:
Hi
i'm using the back hole 1.6.3 image on Vu duo and it seems that EM2882 drivers doesn't work. I try to download them from BH addons servers but i still have the message 'no USB driver found'. i want to use them with a PCTV 330e USB tuner from pinnacle but no luck for the moment.
any hint to make it work ?
regards
