USB Tuner: howto report problems
angelofsky1980
BlackHole Driver Specialist
Dear friends,
I write a simple schema to report information needed to debug your problems with USB tuners.
I hope you follow these instructions for a better support.
Thanks in advance :)
Info about hardware said:
Report info about device like Producer, Model, USB IDs, driver used or any other info useful to identify the device
Info about software said:
Post the return of these commands:
/usr/bin/usbtuner -V
Info from kernel said:
If the activation fails:
- connect to your box via telnet/ssh
- do a dmesg command and report the last 20/40 lines. If you are unsure, save the output into a file with (dmesg > filename.txt) and attach that file in your post.
There are some telnet commands useful to understand what happen on our boxes with DVB-T USB devices.
The commands shown only some infos regarding devices and not personal datas or anything else:
First of all, connect your DVB USB device and reboot your box.
Connect to your box via Telnet/SSH with Putty (I use only that :D ) and follow instructions:
dmesg > /tmp/output.txt
lsmod >> /tmp/output.txt
cat /proc/bus/usb/devices >> /tmp/output.txt
cat /proc/bus/nim_sockets >> /tmp/output.txt
You can upload the /tmp/output.txt file in this Board for investigations.
