Can anyone help me with my usb turbo tuner please.
I have been sent a new one as my old one stopped working, just has a red light on now where as before when it was working it was green. The new one is the same though.
On scanning it pics up nothing.
Seems like nobody knows anything about them?
go to menu -> information -> about and double check if it is recognized if yes go to
menu-> setup -> service searching -> tuner configuration -> and select the USB Tunner (see if it is enabled as well)
on tuner type select DVC-C and Configuration mode put it has enabled, all the rest of the information change to yes (my service scan type is configured to "Frequency Bands")
just noticed that on your first post you said the tuner as the red light on. this happens to me when the tv cable is not connected to it or when there is no signal there. I would recomend you to test with another cable.
tuner settings are - type dvb-c
configuration mode enabled
used service scan type Provider
provider to scan Vigin media UK (6952)
I do a manual scan with - type complete
network scan yes
clear before scan yes
only free scan. yes
not finding any channels??
ive tried 3 different coax cables, don't thnk its that anyway as it worked before, just suddenly stopped.
I thought there was a problem with the tuner as the green light turned to a red and it stopped working.
The supplier could not and still can not tell me why its a red light on and not green.
They have sent me a new tuner but its still the same?
thank you for helping
