USB Wi-FI B/G/N dongle
verbal_666
Hi all.
Can someone kindly recommend an USB Wi-FI B/G/N dongle (mini, i need a very small compact dimension) compatible with SOLO and BH 2.x.x drivers/kernel? Which chipset is surely compatible?
Thanks.
ps. also a PM url.
Hi,
I Use The RaLink WiFi Stick 11n (Ship : RT2870).
No need to install driver for this.
On another SOLO Box I use the : TENDA W311U+ Wireless N150.
http://www.tendacn.com/tendacn/Product/show.aspx?productid=377
Also No need to install drivers for this stick too.
Hope You'll find Your's
I am having TP link TL-WN321G usb wifi dongle but it is not working with BH 2.1.4 I tried but no success even I got another same dongle.Any body suggest any solution
on my vu solo i use an old dlink usb hub
i put a Belkin Wireless G USB dongle F5D7050 in the hub and 32gb memory stick in the hub
and hide it anywhere you like and you still have the front usb port free
and the beauty of the hub is it doesn't need an external power supply
