USB Wifi TP-Link WN823N
dodde
Hello
I was try to get tis USB wifi dongle to work TP-Link WN823N but i did not success , will it be supported in the future , then i will be happy
Hello
I've verified the USB IDs of your device and should be already supported (if you have v1).
Hello
here is the report
Ok I've read your report.
Your wifi dongle is correctly detected but I don't understand what mode you want to use.
You want to use wifi connection in place of ethernet cable?
You want to use wifi connection AND ethernet cable?
Hello
i am just play a little with it , i was thinking to try use it like a AP to test , but later i want to use it on another box i just order
Hello
I've never tried to use a dongle as AP (and I know exists a plugin for that).
You should test the dongle usage as primary connection of your box in substitution of ethernet connection.
