Use of Vu+ WLAN dongle in USB port on back panel !
Don Andres
BH Lover
Is it only me or there are other here on the forum experiencing problems with Vu+ Wlan adapter connected in USB port behind on Ultimo ?
It works just perfect in the front USB port , connected on the back panel it finds the SSID , I define the right type encryption type and key , but NO way , it cold not connect to the network ? :(
Test without a USB stick.
If it works. Then you have to try another USB stick
that will not interfere with Wlan.
