Contact99
I have been using Dreambox Edit Ver 6.0 for my Duo2 and it has been loading all my sat files to my computer but yesterday I decided to test Dreambox Edit to see if I can send back to the duo2 some changes in channel names but even after rebooting noting had changed on the Duo2.
I had a closer look at Dreambox Edit and I noticed where it says "FILE PATHS ON THE DREAMBOX"
I had.
1/ Services and Bouquets Files: /etc/Enigma2/
2/ User Bouquets Files : /etc/enigma2/
3/ Sat.XML file : etc/Tuxbox
Now I always thought that Sat xml files go into /var/etc. (possibly why the sat test name did not change.)
If the above three are incorrect can someone please give me the correct paths for the three above.
Also since I sent my Settings possibly to the wrong folders "example sat xml to /etc/tuxbox while I think that it should have gone to /var/etc can I manually delete them.
Thanks
I had.
Thanks
