Using P+/P- to zap CH+/CH- ( keymap.xml ) for BlackHole
Neotaxi
Good Morning
I have the following problem on my remote control: the CH + and Ch- keys are used to access the channel list and not to change the channel as I wanted it to be. Is there any way to change this function? I would like to know how I can do it?
1) If you don't say what image do you use, theoretically, we can't help you?
This is not a secondary info, it's a primary one!
2)
I can guess you are not using OBH or any other open images, but it's very likely you are using BH or other vuplus code-based images where there is no option to change this from the GUI. You need a different keymap.xml file.
In the open images, like OBH instead, this is the default behaviour.
To use CH+/CH- as P+/P-:
use the file keymap.xml attached (unzipped, of course) and put it in
/usr/share/enigma2
Before that, I suggest to keep a copy of the original as, for instance, keymap.xml.orig
or something like that.
Remember you have to put again your file in that folder after major updates, because it will be overwritten.
After having transferred this modified keymap, remember to restart the GUI.
3)
If you had searched just a little bit you would have found this topic, that has been discussed many, many times.
4)
The title of this thread is completely misleading for readers: this is not a remote control problem: it's a matter concerning the image coding and how they work.
Titles are important for current users and for future searches.
A useful and appropriate title would be:
